FSEQ IMPORT
candrherrin
Trying to pull effects from an existing sequence i only have the fseq for.
Created a sequence imported the fseq as a data layer when played the house model reacts correctly however no effects are visible in the sequencer timeline can see data at the node level doesn't seem to promote to the Strand or convert to effect help
"fseq" file is the object code to be played directly to the lights (like a binary file). As far as I understand, it cannot be reversed to source code (aka effects) since it is targeted to specific channels and pixels. You need to import the "xsq" to get the effects.
can be done BUT i wouldn't recommend !!
long time since I've tried or needed to do this and just got as far as yourself and wonder if somethings changed now
I am trying to figure this out too. a bunch of the shared sequences ive downloaded lately have been in this format. when i go to the google drive it shows everything but i cant figure out how to download it as seperate files, just keeps downloading in the .FSEQ format.
I actual figured it out thanks to a tip from billiam5. They are just a compressed file format. you can either change the file type to .zip extension or what i did was just open it with 7Zip and it opened the file into its separate parts
