John Williams mashup
Christmas Sequence John Williams mashup
danielrenwick
danielrenwick submitted a new resource:
Mash of some of John Williams theme songs. Around 100 hours has gone into this and it includes HD props, pixel forest, moving heads and many more.
To get the silhouettes moving across your show you will need to create a second "All" group. Mine is called "All (put on bottom for fades)". Make sure in your Display Elements and your Master View in the sequence tab that this second "All" group is down the very bottom of the list.
Please turn on allow...
Can I ask please, how many channels on the controller do you need for something like this? Is it a particular controller you like? Thanks
danielrenwick
  • Seller
  • Thread starter
  • #5
I like using Kulps, but there are plenty of other good controllers out there as well. One kulp 32 would do the job
General moving head question so I can get the orientation correct.... When mounted on your roof is the home position of the heads forward, left or right of the crowd? What do you have your xLights Pan and Tilt Orientations set to?
danielrenwick
  • Seller
  • Thread starter
  • #7
It faces to the right in the home position. Pan orientation is 0 and tilt is 338. Let me know if you get stuck, I have put out a couple tutorial videos for those with the MHs facing different ways to be able to remap it in a couple of mins.
