Benny Benassi - Satisfaction (McDonalds TV Ad UK)
Christmas Sequence Benny Benassi - Satisfaction (McDonalds TV Ad UK)
you could say this is where xlights own zip file format comes into its own because you shouldn't be having this problem if you imported the .xsqz
start new sequence
pick the mp3
pick your frame rate
selected your view
then when all is load "import effects" and make sure you are importing the downloaded file Benny Benassi - Satisfaction (Dazwell Edit).xsqz
do NOT import from the .xsq
start new sequence
pick the mp3
selected your view
I've tried reading xlights manual, but that's been published right after the stoneage. It's a steep learning curve, but I found out in the meantime. Thanks for pointing it out.
