ESPPIXELSTICK file uploading issue from xlights using FPP connect
I'm working with xlights and esppixelsticks. After performing FPP connect long files are getting corrupted in esppixelstick. I want to generate sparse files for each controller in PC and then copy paste them in sd card of esppixelstick using a card reader. I'm using FPP sync with esppixelsticks. Please help me to split the .FSEQ file and generate sparse file for each controller and save them in PC. I don't want to do any coding if possible because I'm making the system for a client who will use xlights and maybe he doesn't know coding.
Let's say there are 5 controller. I need to get 5 files splitted from the main fseq file and then copy paste them to the sd cards and insert them to the corresponding controllers.
