Help! Failures second time running playlist
Hi everyone! I am newer to xlights, I am running FPP with a pi zero, 2 relay 8 channel boards for dumb lights and a couple NodeMCUs for the house lights. Right now, the relay boards are powered outside of the pi (I did that after the problem started thinking I was pulling too much through the pi) FPP will run my 15min playlist perfectly through the first go. As soon as it is scheduled to start again it has a failure, and the audio drops. It seems really odd that it would run perfectly the first go-through. If I force a reboot, it will run again. But just once, then the audio drops again. What could be wrong??
PS, the audio is coming from the Pi with a USB sound adapter.
