help
i am trying to sequence some lights. these currently run fine via wled on protocol SK6812 RGBW. however i dont get anything why trying to sequence through x lights.All my setting on the controllers are the correct i think!! does anyone have any ideas?
when using WLED the biggest thing i found was to make sure your using DDP
let Xlights set all the controller info BUT double check the port numbers are right
ChristmaslightsZwolle
Look up the IP adresses of the WLED's, those needs to be the same as the controllers inside Xlights. Also, each controller needs a start universe and universe count. The start universe in WLED needs to be the same as in XLights. Best is to use static IP's via DHCP. On youtube Drzzs has a great video on the first settings.
