Not only that, we offer a marketplace where you can sell your own sequences or showcase them as a vendor
Issues with pixel count
Hey there! I've been doing a ton of research and am coming up empty handed. I'm trying to configure xLights with UCS2904 puck led's (RGBWW) and am using WLED as the controller.
My setup consists of Dig-octa and the first port has 278 pucks on it. I've configured the models as so but the visualizer and node config shows I only have one pixel. I've spent hours messing with this and have had zero luck. Anyone have any suggestions?
Where is your # of Nodes line? (I'm using ver 2025.01 still)
I recreated what you had listed, it seems to have worked properly (with no controller). Nodes numbers do go up to 278.
Hi Mikekrebs,
Yes, I created this with 4 Channel RGBW and had the same issue as you, change nodes to RGBW.
Also, for better render view, change pixel size to 4, all props in my lay out are set to 4, creates really good render videos.
Good Luck
