Signals crossed
So I built my sequence & added all props though visualIzer. Everything matches & checks. However when I plug say 2 snowflak props in to channel 15, they twinkle but doesn’t match the others. Ive tired deleting & re adding. Reset controlle, you name it & still get the same thing. Anybody experienc this?
The only error that shows is for singing props that I have not assigned to any channel. Thanks
myself I would re-render and make sure you've uploaded the control config
failing that id try a "known" working prop on that port
