Miscellaneous Sequence Taylor Swift Singing Faces
youll need to edit what ever your adding the face model to ... (im assuming youll be adding this to some form of matrix and not a singing tree)
i use the defaults but im picking youll just need to add the images youve download to the approprite setting
should be enought info in this screenshot ?
disregard this is a singing tree im pretty sure singing faces appear in just about every model and is only shown as an example
Are you using a projector to display this? What virtual matrix settings did you use to display it?
