Ai created sequences
I am in the process of creating several different auto sequencing tools using Ai. It has been a long process, but I believe I am close to having some finished products ready for sharing....
Is this something that people would be in paying a nominal amount for?
I could offer a general auto sequences for the masses, first, that just places a minimal amount of effects to get someone started....but the ones I'm putting the most effort into are getting to be pretty robust....I'm using a 256 channel AC lights setup with just red white and green dumb lights, though...
*would be interested in
Should have a 30 day trail version, track usage and get inputs that you can make a determination on how much you should charge.
I too have tried my hand at AI, for mapping. Caveat: I'm not a developer nor an AI engineer by no means. I do have something of a rough concept though, but it's very much a work in progress and I've had multiple iterations trying to do everything from generating confidence scores of similarity between evaluated xmodel data to spatial analysis between props and controllers in a layout pic to calculate voltage drops, cable routes, and estimated amperage draws across props. Keyword in all that: try....lots of fail, but it was a decent learning experience.
The concept I've kind of settled on I think should be much simpler. It's just cataloging vendor layouts and aggregating that data to make xmap recommendations for your existing layout. There's a few little extra's added in with visualizations and some AI recommendations. But my hope is that eventually the report package that gets generated could provide all you need to either explain what the AI did for you (if you choose to let it generate the xmap and edited your layout file), or at least give you enough organized information that you could see what groups, subgroups, submodels etc, you would need to edit to get as complete a mapping to each vendor as possible.
I feel like I've learned a lot about the xLights file structure, going from a noob to a partially informed user, and look forward to a day when they get that little "AI Map" button to do its thing. :)
I've been taking this a little differently. I've been using AI to define a framework of how song break down and the create some common building blocks like themes and effect variants. Then using some tools and human in the loop points to refine what's being created. I've spent a couple weeks on it and the results are somewhat promising. It can take an MP3, break it down into timings with different parameters and them assign themes(colors and stuff) and effects onto the timing tracks. It also does things like create custom value curves based on whats going on in the song. It's a bit of a hot mess right now (it generates sequences from an mp3, but the effect choices, layers and groups need work). I'm hoping in another week or 2 I can have something which can generate a halfway decent sequence that someone can tweak/finish up in xlights
It's still a work in progress but hopefully you get get the idea
Downundersequences
Just curious if anyone has used chat GPT to create a sequence? If so, how did it turn out?
mezzyj,
I havnt used chatGpt but I have spent the past few months writing code and putting together a program that builds a complete sequence for you, fully automated, Im thinking of running a webinar for feedback in a couple of weeks
How is the development going on this?
Hi everyone,
I'm just getting started in this hobby and have been experimenting with using AI to help create xLights sequences.
As a test project, I used Claude to help set up a small light show. I provided "A Christmas Fantasy - Disney - John Spiker.zip" as a reference example. I then had Claude generate a two-minute dubstep version of Carol of the Bells and save it as an MP3 file. After that, I supplied the attached prompt and asked it to create a sequence file. It based it off of John Spiker's
I've also included a video of the sequence playing on my house so you can see the results in action.
The sequence is fairly simple, but I think it demonstrates some interesting potential. While it's certainly not a replacement for the creativity and expertise of experienced sequencers, it could become a useful tool for generating ideas, creating rough drafts, or helping newcomers get started more quickly.
I'd be interested to hear your thoughts, feedback, or suggestions for improving the process.
  • Screen Recording 2026-11-06 193053.mp4
    130.5 MB
  • AI Sequince Prompt.pdf
Claude successfully made sequences from scratch, but they were all terrible.
I tried another way that worked a little bit, I would define different sections of the song and then ask for specific things to be created within those sequences. So I didn't deal with individual effects but I asked for things like big movement or quiet and still, what's an emphasis on specific moments. This worked okay.
The best way I found to use AI so far is to download sequences here and then have Claude create three different mappings to my house. I choose the mapping that works the best for my house, and then I'm able to maximize the sequences from this website. This helps me get the best show, but it's still not creating original content.
