- Seller
- #1
how do i download this file? the one that gets downloaded is not allowing me to to im
You need to convert the file this vender provided to a zip file first. Then open the zip file, extract the audio file. Then start a new musical sequence in xlights and import the zip file as you normally would when importing sequences from any other vendor, and then map to your show.When you use xlights to open it are you able to play it?
You need to convert the file this vender provided to a zip file first. Then open the zip file, extract the audio file. Then start a new musical sequence in xlights and import the zip file as you normally would when importing sequences from any other vendor, and then map to your show.how do i download this file? the one that gets downloaded is not allowing me to to im
port
