Christmas Sequence Merry 67 Christmas
how do i download this file? the one that gets downloaded is not allowing me to to im
port
Daka125
  • Seller
  • Thread starter
  • #4
When you use xlights to open it are you able to play it?
You need to convert the file this vender provided to a zip file first. Then open the zip file, extract the audio file. Then start a new musical sequence in xlights and import the zip file as you normally would when importing sequences from any other vendor, and then map to your show.
port
Im having the same problem. ive zipped it but when i try to open the zipped file it opens the sequence. Any help?
Daka125
  • Seller
  • Thread starter
  • #9
@dkelly it is included because I wrote it. Look in the lost folder. It appears there
Daka125
See where it ends as .xsqz...
Change that part to .zip and then right click and do extract all.
