Christmas Sequence Robbie Williams - Can't Stop Christmas [Deleted]
Status
Not open for further replies.
I really like this sequence but it keeps failing on the download. What am I doing wrong?
What error are you getting? Just tested and it seems to be downloading fine.
it downloads almost all the way and then starts over. It does it many times and then fails. I cant figure it out. So far it is only this sequence.
Very odd. Just downloaded it myself. Took about 10 seconds, but downloaded completely.
I have tried another computer with no luck. Also had a friend try on his computer and the same thing happens.
I've just tested and used your account profiles and it worked ok. Has to be an Internet connection issue your end duento the file size.
now it works so forget about above message
Brilliant, glad you managed to download it. I believe it's due to the file size that a couple of people have had issues. It is a great seqeunce through and worth the wait!
Sequence Vendor
This resource has been removed and is no longer available.
Status
