Use every other light bulb
Good day,
I need some help, can i disable every other light bulb so it will not used?
The space between bulb is to small so i was wondering if i can only use every other light bulb.
Am making Matrix for this use case.
Gunnar H.
You can use a sub-model that gathers every other pixel. In your sequences, just drop the OFF effect on that sub-model and put that sub-model on top of the matrix in the Master view.
Obviously you are not saving channels, there is nothing to do to save the black pixels channels.
