Halloween Sequence Free Thunderstruck Halloween Sequence
Hayden
Awesome work dude. can you advise? I import the sequence but my mini spiders are not working the sequence has them as off. Is there a specific effect that is used that i may not have with xlights?
You need to import the spider legs separately. If you double click you mini spiders when you import you will see them separately. Then import leg 1 leg 2 etc
Quite critical how you layer it. If you unlock the zip with winzip then make it a temp directory you can open my layout which may help you.
Can you link the audio track. The one I got from Amazon is about 30 seconds longer then your sequence so nothing lines up.
