KPOP Demon Hunters - Soda Pop
Halloween Sequence KPOP Demon Hunters - Soda Pop
peteandvanessa
peteandvanessa submitted a new sequence:
With the hugely Popular KPOP Demon Hunters Golden song this year, I was asked to sequence Soda Pop since that is hugely Popular this year.
This is a MUST HAVE for Halloween this year.
This really gets the Kiddos and Adults all dancing to the sequence.
Grab a copy now :)
Includes the Sequence, MP3 file, Main singer, Backing Singer, Video Clip, timing track and Lyrics and Lyric timing track.
Easy import to both 2D and 3D displays
Sequence Preview is located here...
I just bought this but i don't see a zip file. I'm not sure what file this is downloading. Do you have a zip file?
nfalzone
I'm in the same boat, you can't download the zip file that has all of the contents all we can download is the KPOP Soda Pop.xsqz file which we need the whole folder if you're providing an edited version of the audio.
nfalzone
I found a workaround if you're still having issues:
  1. Double click the .xsqz file and xLights will open it with their layout and mapping
  2. Go to the top menu and go to File > Sequence Settings
  3. Find where it put the media (Soda Pop.mp3) on your computer and go to that location to copy that mp3 into your main location for your audio
  4. Exit out of xLights completely
  5. Re-open xLights and then create a new sequence
  6. Use that mp3 file for the audio of a musical sequence
  7. Then import effects from the .xsqz file we downloaded
That should work to be able to map the sequence to your layout now.
peteandvanessa
  • Seller
  • Thread starter
  • #5
I have uploaded a zipped file to the google drive location to make it easier to map to your displays. The zipped file contains the sequence, MP3 and MP4 files all in one zipped file.
I got the zip with the 3 files but where is everything else?
When I try to change to that show folder, I get an error message that "Folder chosen does not contain xLights show folder files and is not empty. Are you sure you chose the right folder?"
If I continue and try to open the sequence, the models are missing.
peteandvanessa
  • Seller
  • Thread starter
  • #7
When you unzip the file it will create a new folder (where ever you unzip the file to) called Soda Pop, the three files that are in the new unzipped folder should be called:
1. Soda Pop.mp3
2. Soda Pop.mp4
3. Soda Pop.xsq
The new folder called "Soda Pop" should be moved to your xlights show folder
For example, my xLights show folder is located at:
/Users/peterminion/Documents/Halloween2025/2024 Halloween
So, your xLights show folder will be similar (but different to mine).
To check where your xLights show folder is, open up xLights
It should open up xLights and xLights will document your Show Directory Location on the Controllers Tab
Mine is:
Copy the the new Unzipped folder called "Soda Pop" into that show directory
e.g the new folder called "Soda Pop" will sit under:
e.g you will have copied the folder "Soda Pop" under:
Now start xLight and Create a New Musical sequence
Point the New Musical Sequence to the new Soda Pop.mp3 file in the new file you created under you Show Directory Location
That will create the new sequence, then save the sequence e.g as Soda Pop 2
Then to import the effects, go to the Import effects and select the Soda Pop.xsq file, then map my props to what ever props you are using.
1. Soda Pop.mp3
2. Soda Pop.mp4
3. Soda Pop.xsq
Mine is:
Thank for the quick reply.
I understand what you are saying but the problem is that I can't open your sequence file to see what effects are mapped to what group/prop - like I do with every other sequence I have purchased.
Can't you do Tools --> Package Sequence to include all the models?
peteandvanessa
  • Seller
  • Thread starter
  • #9
I've done it both ways, here's the package sequence attached:
BTW - I've replaced the download link of the zipped file with the a download link to the packaged file so it's easier for folks to map to their displays
  • Soda Pop Package.xsqz
Maybe im missing something. I have never created a sequence directly from a xsqz package. If its easier i am all for it. Can you explain the process? Thanks
peteandvanessa
Sure, I can help.
xLights packages the sequence up into a zipped package. That zipped package has the xsqz extesion to the file name.
The zipped package has three files in it:
1. The sequence itself
2. The mp3 file (song)
3. The mp4 file (video clip)
When you purchase the sequence it provides a download link to the package (zipped file).
When you click on the link it will take you to the google drive location so you can download the file.
When you download the file, i usually save it to a tempoary folder so I can unzip the file to get to all the files.
Then I unzip the file to get all the files, when you unzip them you will get three folders and to additional xlights.xml files.
The lost folder is a pic of my house
The Halloween Soda Pop file has the mp3, mp4 and the sequence files
The shader file has the shaders I used in the sequence.
Copy the MP3, and MP4 and sequence file into a new folder in your xLights show directory
Start xLights and start a new sequence and point the media file in xlights to the mp3 file you copied into your new folder you created in the your xLights show directory
Then save the sequences (you can name it whatever you want)
Then in xLights, go to the top tabs and select "Import effects" and when the pop of box opens, point it to the Soda Pop . xsp file you copied over into you new folder in your show directory. Then map my props to what ever you want to map to inyour layout
Once mapped, then rende rthe whole sequence and save.
Then when you click play it should have mapped my sequence to your layout.
Here's a quick guide on importing to xlights:
Here's a more detailed guide on importing to xLights:
