Monster Mash
Halloween Sequence Monster Mash
Paul Irwin
Craiz submitted a new resource:
Monster Mash
This version of Monster Mash is a fun update to a Halloween classic song. This sequence is a collaboration between Paul Irwin and Jim Dayman. The sequence is focused on isolated rhythms of the song and sequencing movement and color change to different instruments. Lots of experimentation with layers and canvas to create some pretty cool effects and color changes. There are singing pumpkins and a tree for coro props and singing faces on matrices. There are two big matrices, one with atmosFx...
Paul Irwin
Craiz updated Monster Mash with a new update entry:
Monster Mash v2
Main changes in the second revision:
  • Intro with the name of the song drawn on the matrix using the sketch effect.
  • Eliminate the need for double rendering the singing pumpkin matrix faces.
  • New effects to the singing pumpkins matrix faces.
  • A pumpkin at the end rolls into the scene and scares the mummy with Happy Halloween drawn on the matrix using the sketch effect.
  • Adjusted the singing pumpkin matrix face images so the contours of the pumpkin show up better when they...
Read the rest of this update entry...
Paul Irwin
jrlambs
I believe this sequence zip file is missing most of the video files for the main matrix. hoping you can updated it with these files.
dont do halloween altho thought id have a quick look and everything is there ?
it's just in what could be called an older format (standard zip file) and not in the newer xlights zip named file
jrlambs
This is what I get when I map the "P5 Matrix" item to something on my house.
this is one of the video effects on the matrix:
I thought maybe the files would be in the zip and just not mapped correctly, but I don't see them anywhere when I unzip the file and look around.
