Not only that, we offer a marketplace where you can sell your own sequences or showcase them as a vendor
Halloween Sequence Witches Road - Agatha All Along
Are you able to download this? It's only downloading the sequence file and nothing else in the folders.
I hadn’t attempted, it’s not aligned with my music choices, however wanted to offer my opinion to the sequence you made
Lights on Ridgely Drive
Sorry for the delayed response. I did not see there were messages here for this file. The download is an xLights packaged sequence. You can either load it directly into xLights to view, or you can use a free application such as 7zip to extract the contents (at which point you will get all the supporting files (music, video, shaders, etc.,)) that are used in the sequence.
Hi! Sorry for the slow response, I just saw this. The sequence was exported from xLights as a package file. This is essentially a compressed file which contains everything you need to run the sequence (i.e., music, video, shaders, etc.,). If you want to modify it for your own layout, you can use a free application such as 7zip to export / extract the file contents. This will give you the folder structure you are probably used to seeing.
