2023 XLATW Reject Bundle
Christmas Sequence 2023 XLATW Reject Bundle
WiserSequences
WiserSequences submitted a new sequence:
All four 2023 XLATW Rejects in one magical bundle!
To make importing easier, groups were used for nearly every effect.
Sequence includes the following props/groupings:
GE MOAW
PPD GeoWreath
GE Rosa Grande
GE Rosa Wreath
EFL Showstopper Spinner
EFL Showstopper Snowflake
EFL Singing Star
Boscoyo ChromaCane99
Boscoyo DIYC Tree
EFL Mini NSR tree...
WiserSequences
  • Seller
  • Thread starter
  • #4
They look awesome!!!! Any possibility of some moving heads being added at some point?
I plan on learning how to sequence moving heads in xLights in early 2024 and once I feel skilled enough to produce a unique look for each of my sequences, I will likely come back and update each sequence from the 2023 Reject Bundle at no additional cost for those who had already purchased the sequences. No promises, but moving heads are definitely on my roadmap.
WiserSequences
  • Seller
  • Thread starter
  • #6
these are much better than what was chosen for the xlights around the world this year.
I don’t know if I should take that as a compliment considering my Kid on Christmas sequence is one of the 3 official XATW options this year :) It’s hard because their layout and prop selection is very limiting as they try not to favor any given vendor whereas when I use my personal layout (as shown in the rejects) I have a lot more freedom. In any case, please try to film your display for Kid in Christmas and let the XATW team know the video URL, it would be amazing to break through 1k video submissions in 2023!
Glad you like the 2023 reject sequences. Hopefully I will have enough inspiration and creativity to do it next year as well!
WiserSequences
  • Seller
  • Thread starter
  • #7
WiserSequences updated 2023 XLATW Reject Bundle with a new update entry:
2023 XLATW Reject Bundle Update v1.1
The following sequences have been updated to v1.1: Tommee Profitt - We Three Kings.
The following props have been updated for better overall coverage and effect:
Megatree
Peace Stakes
Mini Trees
Spiral Trees
Arches
Whole House
The megatree now contains 2 separate images that need to mapped. These images drastically improve the quality over the previous effects.
If you saved your import file, nothing has been added/removed or changed in the naming so you should be able to use your...
Read the rest of this update entry...
Looks like you are there and with the new effect too!!!! Impressive for sure on both Panic at the Disco and Meaghan Trainor... Let me know for sure if you decide to add movers to the rejects... I have put all of them into my show and would love to have movers for them.
UPDATE: I found them... they were in the images folder under the sequence. Since all of the files were in a single zip file I unzipped it first and then did the import... when you do it this way xLights does not automatically create the Imported directory with the appropriate files and adjust the path... it needs to be done manually. My bad. Importing the update and caught something that may have been missed? For some reason the video for the wisemen on the matrix of We Three Kings is not in the folder. Looks like there might be 3 different ones?
WiserSequences
The video files for the matrix are automatically added to the 'images' folder, and I’ve confirmed they’re included in the existing download package. Your point about using a zip file for easier importing is spot-on; it simplifies the process by auto-extracting files into the correct paths for images, shaders, and videos. I’ve updated the sequence packaging to include 4 zip files instead of 4 folders for easier import. If you encounter any issues, please re-download the newest version and import each zip file individually—everything should work seamlessly!
WiserSequences
Ver 1.5
Alxxa - Most Wonderful Time of the Year
Additions:
Added color transitions to candy canes toward the end of the song to catch the exhale sounds
Added large blue ripple effect to end of the song as it was a somewhat plain ending without a final blast of color
Modifications:
Updated several effect types to 'Scale to buffer' for better importing to individual props and whole house
Fixed "Canvas mode" enabled on certain effects (issue began...
